Hi,
I've finally decided to take the plunge and get myself a desktop DVD recorder - the question is which one ?
On my list of 'must have's' is
UK Spec (PAL)
HDD
DVD-R / DVD-RW as a preference as I also have a Pioneer A05 (- only)
I-Link (DV Camcorder input)
No need for progressive output but should have RGB out.
The model that is looking promising is the Pioneer DVR5100HS - at £500 is feels steep but I guess this is reasonable compared to some of the Panasonic and Sony high end models which are around £650-£700.
Any recommendations would be most welcome !
Thanks in advance,
Teeerex - UK
