Hello,
I know this is probably a stupid question, but how do you transfer videos (in any format) from your computer to VHS? My capture program does not have an output option. I'm sure the answer is simple, but I've been playing around for a while, and the only thing I could come up with was actually recording from the physical DVD / VCD to VHS (not directly from the computer). Thanks for the help!
Thanks for the reply,
I do have this, but what software can I use to output the video? Is the entire computer screen simply outputted? If so, wouldn't this be an easy way to over-ride macrovision or other copyright protection? -
Yes but you need to set it up. Depends on your graphic card. The settings should be in the Desktop properties.Is the entire computer screen simply outputted?
Well, yes and no. Software players, unless hacked, will respect the protection (or at least they should).If so, wouldn't this be an easy way to over-ride macrovision or other copyright protection? -
All I would do is play the video in Windows Media Player. You would want a pretty high quality source though. The direct DVD - VHS option is probably the better option in terms of quality anyway because DVDs and VCDs always look worse on your computer.
If in doubt, Google it. -
A computer won't output macrovision, a flag in the video causes DVD players to do that.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks for the help guys.. I've been away from the computer I have to try this, so I'll be able to test it out tonight. As far as the DirectDVD, it says it can only be used with DVDs inserted into the drive. I'm trying to copy from computer -> VHS without burning the DVD, which is where my trouble came in. Regardless, thanks again for the suggestions / help. I appreciate it!
What editing software to use after transferring VHS to DVD?
By garyg45 in forum Newbie / General discussionsReplies: 8Last Post: 3rd Mar 2012, 10:20 -
Question about transferring a MAcrovisioned VHS tape to DVD
By goodsmartman in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Sep 2011, 20:21 -
transferring old vhs tapes to computer for editing and burning to dvd
By michael109 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Sep 2008, 11:00 -
Transferring VHS to DVD
By Scotty427 in forum RestorationReplies: 50Last Post: 16th Aug 2008, 00:52 -
Good device for transferring VHS to DVD on PC
By ericlhamilton in forum Capturing and VCRReplies: 1Last Post: 17th Mar 2008, 14:42
