If I archive on DV tapes, how long will they last? What (if anything) will happen to the data over time?
Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
I think it's better than most tape formats but not as stable as DVD... There are alot of production houses that use miniDV or betaSP as masters.
How long? good question... Probably longer than youll need the footage.. -
someone mentioned to me tapes last for around 10 years before degrading(audio.. i guess ic an go and check some of my older tapes) and cd's 25.. at least when govt logs info and archives they were throwing around those numbers but i have no source to back that up on
Hi qlizard,
I've seen this discussed before and the general consensus was around 10 - 15 years.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Originally Posted by qlizard
Archive on the DV tapes for now, and when the newer Higher density(blueray) optical storage discs come down in price and are mainstream in about 5-6 years, then you can easily transfer DV to those discs without breaking up your footage.
Long term storage format.
By DaveQB in forum RestorationReplies: 1Last Post: 23rd Oct 2009, 07:37 -
Long-term VCR storage
By echo1434 in forum Newbie / General discussionsReplies: 4Last Post: 4th Apr 2009, 11:17 -
Best format to store DV long term
By Craig876 in forum Newbie / General discussionsReplies: 4Last Post: 14th Jan 2009, 07:59 -
Best video format for long term compatibility?
By mart0224 in forum Video ConversionReplies: 11Last Post: 20th Sep 2008, 23:39 -
Long term storage of home video.
By kreg in forum Newbie / General discussionsReplies: 7Last Post: 6th Jul 2008, 04:50
