  1. DVDs are flickering on my Windows XP system. I tried with PowerDVD, Videolan, DVD Lab, DVD Shrink...
    Only one software that plays without flickering is Real One player.
    This problem started only few days back. Flickering is happening only when I play DVDs. Mpegs, Avis are playing fine.
    Any suggestions?
    Thanks in Advance.
  2. Somebody help me.. please.
  3. Member monzie's Avatar
    Nov 2003
    The Village
    The FIRST thing I would do is UNINSTALL Real One (do you REALLY need it???).
  4. But for now that is the ONLY software that is playing (showing) DVDs properly on my system.
    Dec 2002
    You really don't want that player.
    Generally speaking, Windows players use Direct-X to display DVD's. They de-interlace it to display it, otherwise you get lines on a computer monitor. And usually it only works on full screen.
    Try updating your Direct-X install, or get new video drivers.
    The programs you mentioned, some of those aren't players, so there shouldn't ever be a question of flickering there.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  6. What do you mean by 'flickering'? Are they horizontal lines or flashing like a weak TV signal (lightening and darkening)? Do they repeat in any a sequence (ie: in rhythm with the audio)?
    If it works, don't fix it.
  7. It is flashing like weak TV signal.. more frequently. I didn't observe any relation with Audio.
  8. Downloading the new video dirver solved the problem.
    I have NVIDIA RIVA TNT2 Model 64/Model 64 Pro graphic card.
    Thanks for the support ..
