  1. WHEN I IMPORT AN AC3 FILE TO ASSETBIN IN DVDMAESTRO IT STOPS WHEN I REACHES 90-95 % AND IT SAYS"Cannot locate a frame SYNC word at an expected byte offset.data might be corrupted(0xc1070042)".
    It does the same with all my ac3 files ,WHY???I use vobedit to create ac3 from vob,s.
    Please somebody help!!
    I must use maestro because i want to add subtitles.Or is there another prog. that does the same as maestro.
  2. Hi,
    By saying "create AC3 from vobs" do you mean demuxing?
    I'm using Maestro to insert subtitles too but I prefer to demux with Smartripper and I haven't had any porblems so far.
    Enjoy!
  3. Yes. demuxing.I have tried several demuxing progs. and its still tha same problem.
  4. Yuehhh!!
    It worked when i used Smartripper!!!!!
