Hi,
I have some problems with spumux undel linux (debian sid).
I am trying to make cvd's with english subtitles. I used subtitleripper to obtain a srt file (subtitles.srt) an used the following script for spumux:
<subpictures>
<stream>
<textsub filename="sub_eng_10min.srt" characterset="ISO8859-1" fontsize="12" font="arial.ttf" horizontal-alignment="left" vertical-alignment="bottom" left- margin="20" right-margin="20" top-margin="20" bottom-margin="30" subtitle- fps="25" movie-fps="25" movie-width="352" movie-height="576"/>
</stream>
</subpictures>
this is the content of the sub_spu.xml file.
I read that in linux, spumux searches for trutype fonts in ~/.spumux, so I made a link named .spumux pointing to the the windows/fonts directory of a windows partition.
I used the following command to mux the subtitles:
spumux -m cvd sub_spu.xml < film.mpg > film_subtitles.mpg
And I got the following output:
DVDAuthor:pumux, version 0.6.10.
Build options: gnugetopt iconv
Send bugs to <dvdauthor-users@lists.sourceforge.net>
INFO: Locale=es_ES@euro
INFO: Converting filenames to ISO-8859-15
INFO: Detected subtitle file format: subviewer
INFO: Opened iconv descriptor. *UTF-8* *ISO8859-1*
INFO: Read 124 subtitles
WARN: Read 0, expected 4tten
INFO: Found EOF in .sub file.
INFO: 124 subtitles added, 0 subtitles skipped, stream: 0, offset: 0.22
Statistics:
- Processed 124 subtitles.
- The longest display line had -1 characters.
- The maximum number of displayed lines was 0.
- The normal display height of the font arial.ttf was 0.
- The bottom display height of the font arial.ttf was 0.
- The biggest subtitle box had 652 bytes.
And my film has no subtitles at all.
I don't know what is the meaning of the WARN: Read 0, expected 4tten
And why the longest display line had -1 characters, and the other values are 0. The file arial.ttf is accesible in ~/.spumux/arial.ttf.
I an completely lost.
Please, can you help me?
any idea?
If you have read this long post until this line...
Thank you very much
even if you have not an answer.
Mike.
How to build Hybrid Fontend Debian installer package?
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 5th Nov 2011, 12:28 -
Spumux problem
By Bigfoot73 in forum Authoring (DVD)Replies: 0Last Post: 15th Sep 2010, 16:08 -
Linux themed skin for DVD Rebuilder (for Ubuntu and Generic Linux)
By freebird73717 in forum LinuxReplies: 5Last Post: 26th Nov 2008, 21:27 -
Converting video of any format to MOV or MP4 Linux/Debian
By lordshadow in forum Newbie / General discussionsReplies: 11Last Post: 31st Aug 2008, 11:35 -
dvd to psp fails on debian with ffmpeg can someone see what I'm doing wrong
By oswaldkelso in forum ffmpegX general discussionReplies: 0Last Post: 26th Jul 2007, 08:57
