Hi,
I am trying to read a DVD+RW recorded on my Phillips DVDR 72 stend alone recorder in my PC.
My goal is to do some video editing of the DVD+RW on my PC, before I burn it to a DVD+R, using external TDK DVD drive.
It says “this media is unreadable”…..
Do I need any special software then the regular Win XP ..
I tried with DVDX copy, TDK DVD builder – and no luck………The DVD is been ‘made compatible’ on the recorder before I inserted into the PC,but still can’t read it..…
Any comments>?
Results 1 to 16 of 16
Should have bought a Panasonic and used DVD-RAM if your intent was computer re-authoring.
Too many stand alone DVD recorders that use DVD+RW have this issue that you are experiencing.
Sometimes you just have to put the DVD in the tray and open and close and open and close and open and close until the computer can read it. Sometimes trying a difference model/make of DVD-ROM/BURNER is needed.
Its unreadable in that external TDK dvd writer of yours? I have no idea, just thought that maybe you expect it to be readable in your old dvd-rom drive, many older drives cant read +r/w. Thats all i got, sorry
Thanks, but I was hoping to find a software {like the software (firmware if you want), loaded to the DVDR that allows to read and write DVD+RW}.
I remember a guy on this forum, saying that he records on DVD+RW using his DVDR and then puts the DVD+RW into the PC and then burns copies into cheap DVD-R without loosing quality…unfortunately I can’t find this post..
Please if anybody has done that, reply… -
thor300 MAn,
I think you made my day… my Laptop is about 2 years old. This might be the problem.. I’ll try to read it in my external TDK DVD -+ writer. I’ll try tonight after work!
Two brains always work better!
Thanks! -
Originally Posted by FulciLives
I use Loobsters guide ( http://www.dvdguideuk.dsl.pipex.com/dvdguide/editing1/editing1.htm ) but you need Ulead Videofactory 2 for this.
It can be done quite easily using other software. There's loads of info around here if you search hard enough.
Biggest problem I've had is with the AC-3 audio format the Philips records in not being compatible with some authoring software (that's why you need Ulead Videofactory 2) but agian, there are ways to circumvent this problem.
It may, as has already been suggested, be an issue with your PC hardware, ie the external drive, being unable to read +RW formats.
Have you an internal DVD-ROM in your PC that you can use for the ripping? If so, use this & use the TDK only for burning.Bad advice is pricey...good advice is priceless
I can't warrant what camp this falls into, but, for what it's worth, it's what I believe! -
Originally Posted by van_d_man
If you CAN see the contents of the DVD that you recorded on the Philips, then it sounds like it's something to do with the program you're using to extract the content.
I have a DVDR70, and one reliable way I've found to do the whole process is this:
0. Record what I want on the DVDR70 - don't usually go below M2 mode for quality. I never have to 'make the DVD compatible' since my firmware update on the Toshiba DVD-ROM.
1. I use TmpegEncDVDAuthor to rip to the hard-drive by using the ADD DVD VIDEO option at the source setup stage. I then end up with a single mpg file.
2. If I need to cut out adverts etc, I can precisely trim with Womble MpegVCR and re-save as a new Mpeg program stream. (I like MpegVCR because it doesn't try to re-code, does frame exact editing, and handles the AC3 audio without a complaint).
3. I author in TmpegEnc DVDAuthor using the mpg file from stages 1 or 2 above. Main reasons are that it handles the AC3 audio and doesn't try to re-encode anything. Menus are a bit limited, although you can edit your own templates and get acceptable results.
I'm not an expert and I'm not saying it's the best way or anything like that, but it works OK for me and is pretty quick and simple. Average of 10 minutes to rip a 2 hour movie, 10 minutes to trim start and end and remove adverts. 15 minutes to author to DVD files in TDA and then 15 minutes to burn to a DVDR.
Hope this might be of some help to you. -
van_d_man,
I'm doing exactly what you're trying to do with my laptop (it may well have been one of my posts you were reading !) although the DVD-ROM in my laptop can't read the recordings from my DVDR75.
I've only had the laptop about 2 months.
Instead, I use my LG4040B DVD burner (in a USB2 enclosure) to transfer the recordings to the hard drive using DVD decrypter then burn to DVD-R.
This gives one to one copies with no loss of quality at all. -
Thats all I can tell you.
Tom -
Same here....do it ALL of the time.
I have a Philips DVDR985 - record to an RW - place the RW in my LG4040B burner and use DVDDecrypter , DVDShrink , Ulead Movie Factory 2 or TMPGEnc DVD Author to do anything I want.
I've also never noticed any difference between the AC3 audio on my Philips RW discs and factory pressed DVD's. -
I've never used a DVD+RW in a standalone recorder before. Did you finalize the disc before taking it out of the machine? Yes I know it's an +RW but these disc's need to be formatted to DVD specs before they can be read in a PC. At least thats my understanding. I had the same problem on a Panasonic DVD-R standalone. Just an Idea.
Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing-- -
Originally Posted by CaseyComb
Although I suppose there could actually be a reason for me to use +Rs at some point (and I can't think of it right now), the use of +RWs duplicates my expectations that I've come to live with from using VCRs.
Tom -
You can't finalise a +RW (at least not on my Philips DVDR75) & they work fine in both my other Philips DVD Player, an Afreey & my PC.
I think I've read somewhere that +RW are pre-formatted to be compatible anyway, so unless you've edited on the standalone, it should be in the correct format to meet the specification.
If you edit on the machine then you need to "make edits compatible" (Philips speek) to play them on another machine, but that's ONLY if you've edited the recording on the recorder.
I would suggest that van_d_man's problem lies with his PC equipment, namely the external DVD Burner.Bad advice is pricey...good advice is priceless
Guys, my problem was my 2 y old Toshiba satellite laptop built-in DVD reader, it cannot read DVD+RW ( they didn’t make DVD+R or DVD+RW by this time….)
When I tried to read the DVD+RW via external USB DVDR+_ - I was successful.
Thanks, thor300! -
I guess you forgot that my post (the first post to answer your question) suggested using a different model/make of DVD-ROM/BURNER.
See how simple this all really was?
I still say DVD-RAM is THE way to do PC re-authoring but hey whatever.
mini DVD recorded by SONY DCR-DVD203 unreadable at DVD ROM of PC
By knightatarms in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 31st Dec 2010, 10:02 -
Dubbing from DVR to stand alone DVDR
By LT9000 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 1st May 2009, 16:11 -
cannot watch tv recorded programs on a stand alone dvd
By tercarsha in forum Newbie / General discussionsReplies: 5Last Post: 9th Oct 2007, 14:04 -
Can dvdr's recorded in the US play on UK/European players?
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 2Last Post: 26th Sep 2007, 08:58 -
Can you make a dvdr unreadable?
By nuffskillz718 in forum Newbie / General discussionsReplies: 11Last Post: 27th May 2007, 04:13
