I have a 20-minute .mpg file -- a TV capture done with ATI Multimedia Center -- in which the sound track is about half an octave low. The sound is compleletely in sync with the video, but the voices are low and sound dragged out, as if the sound trrack were playing at 3/4 speed.
The ATI setting for the capture was
Video: MPEG-2, 720x480, NTSC (525), 6.00 M Bit/Second
Audio: 48,000 KHz, 16 Bit, Stereo
Is there a way to correct the pitch of the sound track while maintaining sync with the video? I'm very new to this game, and my unguided attempts so far have been 'way off the mark.
As a matter of curiosity, can anyone suggest what might have caused the low pitch in the capture? All my other captures using the same software and the same settings with the same ATI card have had completely normal sound
No idea why.
Use SOUNDFORGE audio restoration guides at lordsmurf.com
There are high pitch restore filters there.Want my help? Ask here! (not via PM!)
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 13:24 -
How do I completely remove audio over a certain pitch?
By z-kun in forum AudioReplies: 3Last Post: 10th Mar 2010, 09:19 -
Replacing an audio track in an mpeg
By lordhutt in forum AudioReplies: 1Last Post: 14th Oct 2009, 19:39 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Audio Pitch Problem
By Bully9 in forum AudioReplies: 6Last Post: 18th Jan 2008, 01:41
