For some reason, whenever I capture using VirtualVCR as avi either with MJPEG, Huffyuv, or DivX, it takes forever for TMPGEnc to load the file and to seek through it and it often crashes. I have decent system specs other than the 5400 rpm HDD, but I can load these files fine into VDUB and seek no problem, and then I can frameserve to TMPGenc no problem. Just wondering if there are any settings I can use in TMPGEnc or VVCR so I can avoid the hassles of frameserving from VDUB.
What's the correct pixel aspect of HuffYuv, mjpeg and flv?
By brassplyer in forum Video ConversionReplies: 3Last Post: 13th Apr 2011, 00:25 -
It takes a thief
By zoobie in forum Off topicReplies: 5Last Post: 16th Mar 2009, 12:59 -
Encore takes error
By Nikkiss in forum Authoring (DVD)Replies: 1Last Post: 3rd Nov 2008, 10:04 -
Backing up HD takes too long?
By videobread in forum ComputerReplies: 4Last Post: 26th Jul 2008, 13:17 -
TMPGenc Xpress 4/VobSub cannot load .avi with subs
By varu in forum SubtitleReplies: 3Last Post: 14th May 2007, 18:26
