Why don't you just convert the PAL 25 fps audio directly to NTSC 29.97 fps? Why is it necessary to convert the audio to NTSCFilm 23.976 & then do 3:2 Pulldown Encode Mode?
The audio needs to be synced to the video at 23.976 because that
is the video frame rate being sent to the video decoder. The decoder
is making up frames to get to 29.97 -
When converting from one format to another, it's best to start at the "native" frame rate. Since most movies are shot at 24.000fps (which 23.976fps is, more of less), once you get back to 24fps, moving to the other format is fairly easy.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
You could convert to 29.97fps if you wanted to, but you would lose alot of quality and since the conversion is so much more complicated you run the risks of getting sync problems, interlacing artifacts, etc...
Most NTSC footage is stored at 23.97fps and converted to 29.97fps on the fly by the decoder. It is much more efficient and much higher quality. Do a forum search for pulldown or telecine to find out why. Depending on the encoder you use I'd say storing NTSC footage at 23.976fps as opposed to 29.97fps is anywhere from 20% to 40% higher quality.
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 13:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
Difference between 23.976 fps and 23.98 fps ???
By wasimismail in forum Authoring (VCD/SVCD)Replies: 5Last Post: 27th May 2008, 01:42 -
Converting 23.976 fps to 29.97 fps
By wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 19:26 -
20 fps to 23.976 fps Questions
By Maikeru-sama in forum Video ConversionReplies: 39Last Post: 27th Aug 2007, 10:16
