  1. I have tried converting an xvid with ac3 to mpeg2 to put on DVD using tmpgenc. The result seems to be a little jerky. It is only noticable on scrolling text or when something smooth moves across the screen, like a spaceship flying through space. I have my settings below.
    Also, is there a way I can make the audio on the DVD ac3? I am using Tmpg DVD Author, but it seems to only accept PCM or mp2.
    Allan
    Stream type: Mpeg2
    Aspect 4:3
    Fram Rate: 23.976 (int 29.97)
    Rate control: 2-pass VBR (Ave(2150) -> Max(8000))
    VBV Buffer: 224KB
    Profile: Main Profile & Main Level (MP@ML)
    Format: NTSC
    Endcode: 3:2 pulldown when playback
    YUV: 4:2:0
    DC component precision: 9 (also tried 10)
    Nothing else changed except DirectShow filter priority changed to the highest.
    Dec 2002
    Settings on the AVI? Your TMPG settings are for a 3-CDR AVI.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  3. The avi has the following settings (from VirtualDub)
    frame size: 576x432 23.976fps
    decomp: xvid mpeg-4
    Is that what you need?
    What do you mean, my tmpg settings are for a 3-cdr avi?
    Allan
