Hey everyone.. I'm kind of new to converting video files to DVD... I know how to put them on a disc and everything, the only problem I seem to be having is that the way I am doing it, the disc can only hold about 100 minutes of footage. Is there any way I could condense that? I am using TMPGEnc and DVDShrink... I know about using DVD shrink, but I don't want to lose the quality... Any thoughts? THanks for your help.
Lower the video bitrate in TMPGEnc.
If you are currently using LPCM (uncompressed audio) consider switching to MPEG-II or AC3 instead, that will save you a significant amount of space (space you can use for more video), but MPEG-II may not play on your DVD player, you should test first. TMPGEnc does MPEG-II natively, and there are tools like BeSweet for AC3.
If you're only getting 100mins worth of space, you must be using upwards of 5-6000 for a bitrate? If you want more space, lower that number.
Or, use DVDShrink when it's completed. -
Well, in my book, you've already exceeded the max for uncompressed video. Any more and youo'll begin to loose quality although shrink will do a very good job preserving quality if you use deep analisys.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
NO WAY!? Obviously a typo, I meant MPEG-Layer-II as in AUDIO.Originally Posted by jimmalenko
not enough room
By agent222 in forum Video ConversionReplies: 3Last Post: 9th Apr 2011, 13:16 -
After using DVD-RB, is there enough room to make DVD menus?
By sldvd in forum Newbie / General discussionsReplies: 4Last Post: 4th Apr 2010, 00:23 -
connect pc to another room monitor
By blader18 in forum Media Center PC / MediaCentersReplies: 2Last Post: 30th Sep 2009, 16:19 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
Chat Room Required
By Ryudo in forum Off topicReplies: 3Last Post: 21st Jun 2007, 09:35
