Just been given an authored DVD movie which I wanted to make my own backup of. Normally I use DVD Decrypter to read as an ISO and then burn with Nero. This time Decrypter wouldn't get past 99%, it kept getting stuck on a weird file with a .lay extension? What the hell is this, I've not seen it before, does it need to be there?
I can read the disc in file mode using Decrypter and burn using Nero DVD-Video option but it's a pain in the arse, any ideas anybody?
Joe
The disk was probably authored with Maestro. If you are making a backup leave the Lay file behind. It is redundant. If the disk is not encryted, you can just copy it over to your hard disk before you back it up or reauthor it. Nero has a thing against this Lay file and might not be able to burn correctly in video mode.
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 12:44 -
DVD Decrypter to ISO file - missing
By mkr10001 in forum DVD RippingReplies: 4Last Post: 5th Jan 2011, 18:55 -
How do i get 11gb of avi file onto dvd for backup purposes without dual lay
By wolf422 in forum EditingReplies: 2Last Post: 29th Oct 2010, 22:09 -
DVD with .layout and .LAY files
By Case in forum MacReplies: 1Last Post: 9th Sep 2010, 04:00 -
Problem with DVD Decrypter
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 4Last Post: 31st Oct 2007, 14:01
