  1. Hello everybody, i have got a couple of questions regarding dvd ripping. Thanks in advance
    Usually i rip my dvds with dvddecryoter, then i use dvdshrink and finaly nero
    This procedure works for me, but it takes too long.
    My first question is; Is there any kind of software that allows decrypting, ripping and copy in one step?
    Another thing i have noticed is that sometimes, i have an error message while decrypting wich says that its going to use the slower method brutal force or something like that, am i doing something wrong?
    Last question is about blank dvds. I am using RIDATA and although i have a 4x speed recorder, i can only burn at 1x, any suggestions
    Thanks a lot for your help
    Monroe, Mi
    one post is enough: https://www.videohelp.com/forum/viewtopic.php?t=215500
    as i said in the other post, use dvd shrink and it will do everything except burn. as far as the ridata not being able to burn at 4x, what burner are you using? maybe you need to update the firmware
