  1. does anyone have a guide for the best capturing settings using virtual dub so it comes out the best quality capturing tv etc
    USA
    Have you checked out the 'How to' column here under 'capture'/'virtualdub'? If you can't find what you want there, you might try a Google search or go to the Virutaldub website. Just off the top of my head, you can capture with Huffy if you have a lot of harddrive space or Pic Video if not. Really depends on your capture card, your CPU speed, your HD speed and space.
