Results 1 to 9 of 9
    Feb 2004
    United Kingdom of Rain
    hi,
    What is the easiest way to do this and is there a freeware program I can get?
    Thanks,
    Joe.
    Feb 2004
    very helpful, thanks Redwudz
  3. Member louv68's Avatar
    Feb 2004
    Minneapolis, USA
    This method works for me. You'll need to edit the tracks out of the huge WAV file that will be created. It's a bit of work, but you'll be pleased with the results.
    http://www.area450.com/create/dvdtoaudiocd.htm
    Jan 2004
    Jacksonville, Fl
    You could use DVD Audio Extractor. Works well and in just a few clicks I have working WAV, MP3, etc., files.
  5. Member steptoe's Avatar
    Have a look at ac3tool, is totally free, and can extract any audio from any DVD, and also convert it to WAV or MP3
    Can also downsample 6 channel audio to stereo or surround stereo
    Its very small, and very simple to use
    Feb 2004
    #Thanks again all. I dowloaded ac3tool10.exe but the DVD Audio Extractor points to a bad link.
    I managed this last night (in a rough way) by using Cool Edit Pro to Extract from Video (under File option). It opens the whole DVD *VTS file which you then have to edit which bit you want, but hey, it worked.
  7. DVD audioripper from I think ImToo also works great. you can go up to 320 kb mp3.
    Feb 2004
    thanks Wings
