  1. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I just dug out and dusted off my wife's old Philips CD Recorder that I needed to use. I still have some Music CD-R's luckily but something got me thinking.
    Is there a way....via computer perhaps....to make regular CD-R's compatible in a CD Recorder that only accepts the "Music" versions?
    Just curious....
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Nah. Basically, it's pressed (commercial) vs. burned (dye).
  3. I've read some tricks about using cd-r instead of audio-cdr I don't exactly remember but you insert an audio cdr and then press 'pause' and replace the audio cdr by a cdr, but as I have no audio cdr burner I can't be sure
