I am using a MPG as my menu, using TDA is there a way to get it to play once and then stop. i dont want it to loop and start again.
thankyou
So i take it that this cant be done,
does anyone know if DVD-LAB can do this ?
what i will try and do is have the Video go for 5secs and set the MPG Loopage time to 30secs, so it will play for 5 secs then stay until 30 secs then it will loop. maybe that would be acceptable. -
a video loop to mimic what you are trying to achieve. In Scenarist
you can set the total loop time and the next play video (or menu)
but not in Tmpgenc DVDAuthor AFAIK - same goes for Movie Factory,
Workshop and Media Studio Pro. SpruceUp can also do it I think. -
Possible workaround/bodge that might work with dvdlab
make 2 identical menus (but one with the mpg as backround and one with the still)
then link the motion menu to the still (dont know if you can do this, not got dvdlab loaded at the mo)
Looping DVD with no menu
By SCDVD in forum Authoring (DVD)Replies: 7Last Post: 21st Feb 2008, 20:12 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 00:37 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 19:43 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 03:53
