I have a Winfast TV 2000 XP card using the software that came with it. The documentation with it is sketchy. I would like to record a TV show so that I can burn it to a DVD and then watch it on my standalone DVD player. I tried one yesterday (not using Directburn) but the result was a large mpeg file that won't open with PowerDVD on my pc so there's no point in burning it to a DVD.
How do I correctly set up the software to record so that I end up with Audio_TS and Video_TS files that I can create a watchable DVD from? Also should I stick with the stock software or is there something better to use?
Tia for any help and advice.
Gary
I use power VCR to save the capture to mpeg2. Then you could use TMPG author to prepare it for burning. There are other programs that could do the job.
look at this guide
https://www.videohelp.com/guides.php?guideid=455&howtoselect=3;6#455"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
hey I have the same capture card
Ya you can use the capture software that came with the card or use something else.
I like to use WinDVD Recorder:
https://www.videohelp.com/guides.php?guideid=142&howtoselect=9;50#142
Then I author the DVD with TMPGEnc DVD Author.
*HELP* Capture xbox360 need advice
By trusoljuh in forum Video Streaming DownloadingReplies: 0Last Post: 7th Apr 2010, 14:32 -
Video Capture Advice
By Windu in forum Capturing and VCRReplies: 6Last Post: 15th May 2009, 11:30 -
MiniDv Capture Advice
By afoote@acslink.net.a in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th Nov 2008, 06:22 -
capture advice
By atvmxr in forum Capturing and VCRReplies: 4Last Post: 10th May 2008, 18:32 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 19:18
