Results 1 to 9 of 9
  1. Member nick101181's Avatar
    Sep 2000
    Toronto, Canuck Country
    I typed in 352 x 480# just like lordsmurf's site said to do at allvideosizes registry key, then rebooted but I don't see it anywhere when I start the program. Also do I have to change the deinterlace registry settings at both powervcr locations in the registry or just the one under software in hkey local machine? I want to add the following sizes to powervcr II 3.0 deluxe 352x480 and 544x480. I want to test the 544x480 cap from dtv cause I know it uses that resolution. thanks
    Double-check it.
    You have all the punctuation (#) in there right?
    I know the setup part of the guide works.
    I got sidetracked on the actual capturing aspects.
    MainConcept 1.4 made the cut finally too, will share that soon.
    Those are the only 2 good options.
  3. Member nick101181's Avatar
    Sep 2000
    yes this is exactly what i have at the end of the value is 352 x 480#. I want to also add 544 x 480# too. Do you think lordsmurf, that if i cap at 544 x 480 around a 2000kb vbr that the results should match the dtv stream as closely as possible? I know you can patch the header to make it compatible for certain dvd authoring programs. I know not all dvd players will play a disc like this but most should. I read on your site that dtv broadcasts mpeg 2 at 0-2000 kb, so this is where I came up with my idea for this.
  4. Member nick101181's Avatar
    Sep 2000
    I've been trying to figure this out but I did it the right way and it didn't work yet. Can someone make a reg file for me that has the settings 352 x480 and 544 x480? I changed the deinterlace values already but the size is not working for me when I put 352 x 480#. I would appreciate it alot. Please pm it to me or something. thanks
  5. Member nick101181's Avatar
    Sep 2000
    ok i got it to work. it wasn't in hkey local machine i had to change the settings it was under user or something then it worked. thanks
    Change both HKEY_LOCAL_MACHINE and HKEY_CURRENT_USER
    I didn't have to do that on my Win2K machine, but apparently I must on a WinME or XP machine. Odd.
  7. I tried to do the same like on lordsmurfs site http://www.lordsmurf.com/ , but it still not work. I have 352 x480 and 544 x480 on drop down list, but when I try to transcode in this resolutions, the resolution of output file is 720 x480 (NTSC). The same situaton is with PAL system. .Also when I transcode (live) from DV input (Sony D8 camera) to VCD the output file have very strange resolution 366 x240 instead to 352 x240-VCD standard. When I do the similar thing, but just convert (convert file option) captured AVI from the same device to VCD, the result is ok.!!! I am a little bit confused. Is the POWERVCR so HORRID software, or what?! Can you e-mail me REG file (if all works fine on your computer- lordsmurfs or nick101181) .com. Thanx a lot!
    Cheers,
    Luna
    Any IDEA , about other software for live transcoding (DV -> VCD or SVCD), what is good for my computer PIII 1Gig, 256Meg RAM, FireWire, 2 x SATA HDD.
    I'll work on getting up some downloads on my site. I've got some in the plans, just haven't had time to upload them and add the updated site pages.
    I also added MainConcept 1.4 settings, which can work decently too, but it takes a LOT of tweaking too, and is not friendly on most systems I tested with. Gotta have powerful CPU and lots of RAM.
  9. O.K. Will you be so kind, and let me know when that downloads will be ready on your site! Thanx
    Cheers,
    Luna
