I started using AutoGK to convert DVD to DivX/XviD today. It works great, there is just one question I am having trouble finding an answer to.
In AutoGK, you can select the output size from either a predefined size, a custom size, or target quality (in percentage). The problem is, I am dealing with a clip that is only a couple of minutes long, and trying to figure out the lowest size I can make it, while still having the quality decent. There are many bit-rate calculators out there, but they generally require the 'output size' in the calculations, and that is what I don't know.
Is the only way just to experiment with custom sizes ? (5 megs.. 10 megs..) or is there a better way to figure out the size a 2 minute long file in decent quality 'should be' ?
Ia! Ia! http://www.templeofdagon.com/
It comes down to bitrate. I would consider a decent quality Divx to have a bitrate of at least 1000kbps. Assuming the file had 128kbps audio and 1000kpbs video the resulting two minute clip would be 16-17mb.
yes or experiment with diff quality settings (only one pass needed so twice as quick)Is the only way just to experiment with custom sizes ? (5 megs.. 10 megs
I agree about bitrate over 1000k generally looks pretty good 700k and under is low quality.Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
creating many small clips w/ mpeg ts file
By Funkymoses in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2010, 11:53 -
Putting lot of small clips toggeter
By red_d in forum Video ConversionReplies: 2Last Post: 7th Mar 2008, 21:51 -
Small MPeg clips From Cam
By vinnyv07 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jan 2008, 14:28 -
How to create small clips from a movie!
By unstopabl3 in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2007, 04:34 -
Small Quicktime Clips in a Premiere Pro Project
By foochuck in forum Newbie / General discussionsReplies: 0Last Post: 25th Jul 2007, 22:27
