I recently updated to Toast 6.03 and OS 10.2.8 on my computer. Prior to updating my software to the latest versions, I hadn’t had any problems burning movies using Toast 6.0. The problem I’m having occurs right after I push the burn button in Toast, these two files (Desktop DB and Desktop DF) get added automatically to the list of files getting burned. After I have already begun to burn the disc, there isn’t a way to delete the Desktop DB/DF files. If I stop the burn to delete these files, the DVD becomes a coaster and the DVD is ruined.
If I let the burn finish all the way through, I get an error message that says ( “There was a system error”; “Could not detect a valid media file”) when I attempt open the Video file on my G5’s DVD player. If I push the play button it says (NOT PERMITTED) on the screen.
The steps I use to burn a movie with Toast are the same steps I having been using since I started to backup my movies. Here are the steps, first I use DVD Backup to backup the movie files onto my hard drive, then I use DVDZoneX to process the movie files, finally I use Toast to burn the DVD files onto a DVD. Thanks.
Results 1 to 1 of 1
Problem burning subtitles and movie to DVD with Toast
By Akominatus in forum MacReplies: 40Last Post: 14th Apr 2013, 14:28 -
Burning a DVD ripped with MTR without the Toast application
By FilmLabAsst in forum Newbie / General discussionsReplies: 1Last Post: 20th Sep 2010, 11:58 -
burning a DVD in Toast
By lalilyman in forum Authoring (DVD)Replies: 3Last Post: 30th Mar 2010, 22:11 -
burning clips with toast
By 3mselect in forum MacReplies: 6Last Post: 29th Oct 2008, 12:54 -
After burning in Toast: subs: no and yes.
By Levina in forum MacReplies: 7Last Post: 13th Apr 2008, 16:50
