In the eternal quest for higher quality capture, I've been looking at purchasing an S-VHS VCR which will not break the bank. I think I have found one, but I'd like some expert opinion if possible. I'm in the UK, so I don't know if this model exists elsewhere...
JVC HR-S5965 S-VHS Nicam VCR
I can get this deck for £99.98 / $184.65
Bearing in mind I'm using an AIW 9800SE card, will this JVC afford higher quality captures over a normal VHS (my current VCR is pretty terrible, mono sound and all)? Is it worth spending a little extra for the S-VHS advantages? Is this particular S-VHS model up to the job? Thanks in advance for any advice.
S-VHS makes a huge difference. Get it. JVC are known to produce good S-VHS decks. Make sure you get 3R-DNR on it and maybe Time Base Correction as well.
There are no stupid questions, only stupid people. -
Excuse my ignorance on the matter, but what is 3R-DNR and what exactly does Time Base Correction do (I've heard it mentioned but am unaware of the complexities - if there are any!)?
You should probably look over this recent thread if you haven't already, and this guide on lordsmurf's site.
https://www.videohelp.com/forum/viewtopic.php?t=213802&highlight=
http://www.digitalfaq.com/capture/vcrtbcsuggestions.htm -
Thanks - LordSmurf doesn't seem too impressed with the JVC budget range of S-VHS VCRs. I don't know if this model above has a TBC or DNR. Even if it doesn't, surely it's better than a normal VCR, right? Would it still be worth it?
Don't expect a SVHS VCR playing normal VHS better then a normal VCR.
Often that is not the case at all.
But if the VCR has some form of TBC that would surely help a lot for good captures...
VCR buying guide (S-VHS / D-VHS / Professional)
By lordsmurf in forum RestorationReplies: 326Last Post: 2nd Sep 2025, 05:10 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 00:54 -
JVC S800U worth buying for VHS restoration/conversion
By mark23 in forum Capturing and VCRReplies: 1Last Post: 11th Jul 2008, 11:22 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 08:19
