Is there a possibility to copy (rip) music on DVD and burn it on CD so I can listen to it on a ordinary CD-player ?
If so, how do you do it![]()
Thx in advance![]()
Here's one way you can achieve this:
- Find the music you want to get. Note the start and finish times.
- Rip your DVD.
- Open up in DVD2AVI.
- Find the start and click the "[" button.
- Find the end and click the "]" button.
- Set it to downmix to WAV.
- Open the resulting WAV up in your favourite audio editing app, and take what you want.
You can burn this WAV to CD using your favourite burner.
Hope this helps.
Cobra -
Any of these apps. will rip a DVD to wav.
"Art is making something out of nothing and selling it." - Frank Zappa -
Intrud€r: You do realize that the entire audio track from a DVD is many times bigger than will fit on a CD as a WAV?
A single stereo audio track should be about 1 GB and a CD is 700 MB.Originally Posted by redwudz"Art is making something out of nothing and selling it." - Frank Zappa
Extract the audio from the DVD using SmartRipper ... this guide is very helpful :: http://www.glump.net/content/audio_dvd_rip/guide.htmOriginally Posted by Intrud€r
I use SmartRipper (as shown in the guide) then I feed the AC3 into BeSweet ...see: http://www.doom9.org/ac3tomp2.htm
The SmartRipper option (set up correctly) only rips the AC3 and then the BeSweet conversion makes a pretty damn good MP3 -- I like it better than HeadAC3
Encode your AC3 into the LAME "Alt_Standard" setting and you will fit it on to one CD NO PROBLEMyour pal,
Stinky
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 22:03 -
Replace Background Music with New Music without affecting other tracks
By PaulDHolloway in forum AudioReplies: 3Last Post: 10th Apr 2008, 13:56 -
How To Rip and Manage Music DVDs just like Music CDs in JRiver Media Center
By jmone in forum User guidesReplies: 0Last Post: 13th Oct 2007, 19:15 -
Can I burn a music video along with music trax onto the same disc?
By Kalla B in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 13:02 -
MP4 Copying music to device??
By skippy_kay in forum AudioReplies: 0Last Post: 10th May 2007, 04:00
