ive got a DVDR+ made with my TV dvd recorder but when I try to ghost to my hard drive with CloneDVD and.... DVDcrypter both get errors ive tried cleaning the disc but no luck, other DVDR+'s ive made with tv recorder have worked before why not this disc????
Results 1 to 12 of 12
DVD region settings are a joke, I can't believe how stupid people are falling for it
Is it a different brand to the others? If so, it may be disagreeing with your DVD-ROM. Have you tried SmartRipper? I find that sometimes it can rip dodgy discs better than other applications can.
Cobra -
I use TMPGenc DVD Author to get films from my DVD+RW recorded on Philips DVD Recorder to my HD
Thats just I want to get it ghosted to my HDD so I can remake it with all new menus etc, if you import from direct from DVDR+ I make with my Phillips DVD recorder if then import direct into DVD author than it comes out with no sound, I have to ghost it too my HDD with Clone DVD or DVD Ddecpyter 1st and its not letting me do itOriginally Posted by andyp1DVD region settings are a joke, I can't believe how stupid people are falling for it
Yes, but when you watch them back afterwards im seeing it but hearing silence, only happens with ones ive made with my TV recorder anything elese works fineDVD region settings are a joke, I can't believe how stupid people are falling for it -
Sorry it works for me and I haven;t used any other method
Hopefully someone will know. -
what's your TV recorder??? mines a Phillips DVDR70
So when you load up Tmpgnc DVD author and remake your DVD you did on your TV reocrder they come out fine you have no problems with the sound or anything???Originally Posted by andyp1DVD region settings are a joke, I can't believe how stupid people are falling for it
No Problems , I stuck the DVD in Open TDA ,Create New Project.
Add DVD Video , find the VIDEO_TS folder , open it , Select the recording I want . Check the box that says ' copy the clip video to the HDD' , Tell it where I want it and let it rip.
Close TDA and Ive got an MPG on my HD , when I play it it is there with sound.
When I have enough Clips to fill a DVD-R I use TDA to create Menus and chapters.
Thats it -
Just to let you know I had a disc to transfer , so I tried DVD Decrypter in file mode and just ripped the large vobs , there were two movies on the disc and it worked ok
DVDR's with hdd question
By tannenba in forum DVD & Blu-ray RecordersReplies: 1Last Post: 13th Feb 2011, 13:43 -
Copying from standalone hdd recorder's hdd to pc hdd
By flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 07:17 -
jerky avi playback after copying to HDD
By mdrobbins in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2010, 10:04 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38 -
Copying DivX to HDD on a Panasonic DMR-EH57
By Ouchies in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2008, 07:05
