I need input from smarter brain than mine. If I test a burned DVD with Nero CD Speed disc scan, both file and surface test, can I be confident that the burn is actually good and the surface is reliable ( excusing any problems in the future from dye decay). It appears as though that is what the software is saying but I have burned discs with very visible flaws and I get no errors. Is this a reliable test of the quality of the burn?
Thanks in advance.
Still a few bugs in the system...
Yes Indeed, I would also run a speed test too.I myself usually first run a speed test to see how the graph is if it's has little to no spikes then it's a good burn with no errors. If there is heavy dips in the graph then you no thats where it slowed down and had a hard time reading that sector. I have the rip locks removed on my Lite-On 166S so it hits 14x read speed, the faster the better then you can really tell how good the burn is.
James B Elder
Nero CD/DVD Speed (4.7.7.5) -Error
By bluemoss in forum DVD & Blu-ray WritersReplies: 14Last Post: 12th Jan 2012, 00:08 -
Strange DVD SPEED test results
By tac7 in forum DVD RippingReplies: 5Last Post: 2nd Apr 2009, 22:24 -
Speed Test Results
By HmNtr in forum Off topicReplies: 0Last Post: 28th Dec 2008, 02:58 -
converting to AVI or mp4 with stand alond dvd recorder..speed test
By diablo_ogre in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2008, 10:55 -
Comcast speed test.
By Poppa_Meth in forum ComputerReplies: 7Last Post: 27th Aug 2007, 10:28
