  1. Hello I got a film on my computer thats on 4,5 gig and i want to play it.
    It is in a .rar format and when i open it, there are some files called .VOB , .BUP and .IFO ... How should i do to play these files??
  2. VOB is the movie file you need either PowerDVD or WinDVD or similar application to play the movie. .rar is a zipped file so you need to get WinRar to unzip the film first
    hope that helps
    alright
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You will need winRAR to extract the files to somewhere on your Hard Drive. Then use PowerDVD or something similar.
    If in doubt, Google it.
