I have a mpeg2 file which is 24fps NTSC(TMPGEnc shown). I used the method which vcdhelp.com shown to convert it to mpeg1 file. But the output mpeg1 file had a big audio problem which a large audio lag on it. Besides, i found that the video part is shorter(or slow)than the audio part, such as 1 min audio part had played and only 51 second video part were played ( i know that coz i have watched the mpeg2 by PowerDVD). I had tried many different frame rate while converting by TMPGEnc, but it still not work.
Can anybody help me?...Thanks a lot
I used TMPGEnc, DVD2AVI, Virtualdub...
mpeg-2 to mpeg-1 is fine, but did u keep the framerate (24fps) the same? if not, that's ur problem.
Thanks hitechjunkie,
I have tried all default settings at TMPGEnc(VCD PAL,NTSC,NTSCFilm),but the results were same[I had not completely encoded the files, i only did part of it coz it is very large. Would it affect the result?].
Besides, TMPGEnc can read the mpeg2 file now, can i convert the mpeg2 file to mpeg1 directly without using DVD2AVI?
And the problem should be audio lead the video...51 second mpeg2 video had been converted to 1 min mpeg1....THANKS
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 21:49 -
Converting MPEG2 Audio from AC3 to MPEG1 Layer 2
By jrisch in forum Video ConversionReplies: 8Last Post: 8th Dec 2009, 21:28 -
remuxing mpeg1 audio to mpeg2
By ChaosOrb in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 15:25 -
Audio adjustment for 25fps to 24fps
By ranosb in forum Video ConversionReplies: 29Last Post: 12th Aug 2009, 21:17 -
24fps HD-MKV (H264/VC-1) to 25fps SD-MPEG2
By Nightwalker_z in forum Video ConversionReplies: 9Last Post: 27th Apr 2009, 10:31
