I seem to be having a problem with the region code on a disk when I try to make a copy of it. I use any DVD and Clone DVD but when burned to disk and I try to play it it just shows the federal warning and then a map showing the region code numbers!. I have also tried it with DVd decrypter and clone DVD with the same result!. I have also tried to play it on my computer using Power DVD with the same result!. The original does play fine on both. My region is 2 and the region of the DVD is 1 but my standalone plays anything anyway. Anyone any idea, thanks. Could this be something to do with RCE as I have been told it could be?.
Sounds like it could be - make sure the correct RCE region is selected in the DVD Decypter options.
Thanks, but should this be the region code on the movie or my own region code?. I am unsure on this.
in Decryptor set the region code to the code of the movie itself and it will crack the RCE correctly.
Hi Guys
I've got Identity & Runaway Jury - but I keep getting the world region zone's map thing when I copy the disk to the HD (via DVDDecrypter). I've set the RCE Protection Region to 1 before copying as advised but it still doesn't work
Any ideas what's up ?
Cheers -
are you sure the original DVD is region 1? check the back of the box. if its something other than 1 set the region code to the region it lists. there are also some DVD players that do no like no region and all region discs.
RCE Protection Issue
By tryst1 in forum Authoring (DVD)Replies: 1Last Post: 24th Jan 2010, 09:53 -
RCE protection removal..............
By efiste2 in forum DVD RippingReplies: 12Last Post: 21st Jul 2007, 12:42
