  1. Thought things were going too well. Successfully DVD'd about half of my collection of ancient aircraft VHS tapes. No-name Conexant capture card with latest BTWIN drivers - VirtualDub & TMPGEnc on a 2400 AMD. Good so far. Now I have a problem. The current tape just will not capture. The frames seem to jump, as though the current frame is overlain with a previous image and flickers back and forth. Play it back through the VCR/TV normally and it's fine.
    Tried different capture settings and different application - no change. I'd try a different VCR if I had one.
    Back in the bad old days of audio tape we used to run into the problem of old tapes 'bleeding through' signals between adjacent layers - does that happen with video? It feels as though something like that may be happening - not enough to show up on a VCR but enough to throw the capture mechanics, maybe ?
    It seems to be 100% consistent. Consecutive captures of the same bit of tape show the same problem frame for frame as far as I can tell. Other tapes from the same series show no problem at all, although having more carefully reviewed some of the disks burned so far I have found the occasional glitch. Looks as though most may have the problem to varying degrees. The VCR is 6 months old - no visible defects - apparently plays fine. I have rewound the tapes a few times to make sure everything is tight but no change so far.
    Any ideas would be much appreciated.
  2. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Do you have a dv camcorder you can do a pass through? via a firewire card. If not........sorry I can't help.
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
  3. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Video can bleed through if the tape was used a few times.
    You may want to hook another VCR up and dub to a different, new high quality, blank tape, then play back that dub. The use of a "copy master", "copy gaurd" device inbetween the two VCRs will help.
    If that doesn't work-
    Try to capture something else, TV etc.. To make sure your capture settings/PC are working correct.
    If that works, try a different tape, perhaps your VCR has a problem, try cleaning it.
    If all is good, except that tape, try a TBC as a last resort.
