I'm ripping with Smartripper and I use stream prosessing.
I check the video file, language and subtitles - then I save the selection and start ripping.
I've tried DVD Decrypter as well, with the same result....
Then I use DVD2AVI (no subtitles here, but the language is OK) and TMPGEnc (no subtitles here either) to make my mpg-file.
The final mpg-file has no subtitles either...
What am I doing wrong?
...000....000....
Angelot :-D -
OK - I found out that I had to rip subtitles separately...
And I've done so with VobSub...
With DVD2AVI and TMPGEnc Plus I made an mpg-file.
And with VobSub I made a sub-file.
With VirtualDub MPEG-2 I loaded the mpg-file and the VobSub-filter - the output-preview was perfect...
Then I tried to start the frameserver, but it only accepts avi-files.
Is the only alternative "Save as avi", or can I save (or framesave) as mpg in some way.
I would like my output to be an mpg-file with subtitles......000....000....
Angelot :-D
Need help with subtitles for Avatar rip
By elgoocho in forum Blu-ray RippingReplies: 1Last Post: 14th May 2011, 23:29 -
Any way to rip/demux .ts h264 subtitles?
By rocka in forum DVB / IPTVReplies: 5Last Post: 2nd Jun 2010, 15:08 -
Rip subtitles - won´t work.....help
By manutd in forum SubtitleReplies: 2Last Post: 9th Nov 2008, 16:24 -
How do you rip subtitles from a DivX file w/4 subtitles
By JoeBolden in forum SubtitleReplies: 2Last Post: 21st Nov 2007, 14:46
