    Feb 2001
    australia
    i have tried Virtual dub and nanadub and AVMUx
    they have syc problems and AVIMUX wont open it
    HELP!!!
  2. then u have to manually Sync it, many times u will have to do this for DVD rips. http://www.doom9.org should have a tutorial in the GUIDES section.
    Feb 2001
    australia
    I have tried but it is impossible, it dont work hey
    any other ideas?
  4. ive had to do it several times and have found it very easy, sorry, no other ideas. i hav done Gladitaor and Saving Private Ryan, took a bit of figuring out and they were difficult but after about 5 mins i got it down perfect =)
    Feb 2001
    australia
    i msut say that has pissed me off, dam you!, i have been trying everyhting and still fuks up
  6. Member vhelp's Avatar
    Mar 2001
    New York
    nightstalker,
    Try and break it down to a smaller file, or 1/2 hour clip and
    test it to see if it still de-synchs! Can be many factors,i.e,
    * adding new frames
    * cutting in the wrong place
    * joining in the wrong place
    * clip is just too long (for your sys. spec)
    * sound card config +/- sys. spec
    * etc.
    Just cut the dam clip in half somewhere, ...maybe where it transitions
    or where sound cuts out or fades out or something, etc.
    How are you getting your source?
    * Is it from a cap to avi or dvd rip or somthing?
    * How are you arriving at your mpeg? ...hardware mpeg?
    Feb 2001
    australia
    It is a DVD rip
