If i try to convert AVI files with TMPGEnc which use Divx3 as video codec the mpg-file dont play smooth. It looks like that about every few seconds the picture stops for some milliseconds. If i watch my avi befor converting it with e.g Windows Mediaplayer or VirtualDub the avi runs totaly smooth. I have installed the following codecs: Divx5.1.1 Package, Xvid from Koepi and 3viX.
I have noticed the following:
- avi videos which use divx5 are converted ok
- if i load the divx3 avi in VirtualDub and recodes it with 3viX and then use the 3viX-avi-file to convert with TMPGEnc the result is like it should be
Has anyone a solution for my problem?
thx so far
N8mare![]()
Results 1 to 1 of 1
Smooth accelerated video
By Bluelemmy in forum Newbie / General discussionsReplies: 24Last Post: 24th Feb 2014, 17:13 -
video playblack looks blocky. how to make it smooth?
By zzyzx2 in forum Newbie / General discussionsReplies: 6Last Post: 11th Oct 2009, 23:29 -
Instant Handbrake: Video size result?
By Jeikobu in forum MacReplies: 5Last Post: 17th Jun 2008, 21:14 -
Tmpgenc Express rendering real video, result no sound
By pcb in forum Newbie / General discussionsReplies: 0Last Post: 31st May 2008, 14:17 -
Video to smooth, what do you recommend.
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Mar 2008, 12:28
