  1. Member kpoman's Avatar
    Jan 2003
    Anyone have the executable flash FS0F for the Liteon LDW-411s? I can't seem to find it anywhere. Im not having any luck burning DVD-R media using the latest flash (FS0J) with this drive. Im trying to burn DVD-R 4X Maxells and all I make are coasters. Thanks.
    Live Long, Play Hard, Think BIG!
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    http://dhc014.rpc1.org/indexOEM.htm#L
    I think this is what you're looking for but I could be wrong. I have the same drive 411s but I haven't tried burning MAXELL DVD-R 4X. Since you've mentioned you burned coasters with them. I won't be trying them out. I'll use them on my other burner Plextor 708A. What software & programs are you using that is could be causing coasters for you?
  3. Member kpoman's Avatar
    Jan 2003
    Thanks for the link. I use DVD Shrink and RecordNowMax to burn and I've never had any problems with DVD+R media.
  4. Banned
    Nov 2002
    Pgh Area
    kpo,
    I've mailed the zipped Windows flash file. Unzip and double click to run.
    The link above only has the binary to run from a boot disk, don't know why.
    I had no problem with -R after flashing, but haven't tried Maxells.
    Burn mostly +R, as most compatible with my kid's machines, and I bought a couple hundred at sale prices, Ridata, Philips, Mems, even Khypermedia. Burn all well.
    Cheers,
    George
