Results 1 to 16 of 16
  1. I have a few AAC files that show up as blank document icons. They won't open in iTunes, and only open in VLC. Is there any way to convert them to MP3s or something? Thanks
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    you can't import them into iTunes?
    What version of iTunes do you have?
    Nov 2003
    New New York, Year 3000
    what is the file extension on these aac files?
    If it isn't broken, take it apart and find out why.
    blog: deadsierra
  4. i have the newest iTunes, and the extension is .aac
    it's wierd as hell, i know. they wont open in quicktime either.
  5. Member terryj's Avatar
    if you change the tag to .mp4, does iTunes now let you import them?
  6. no good. they imported, but they didnt play. also, the time of the song said "not available"
  7. Member terryj's Avatar
    Play them in VLC again, but this time, while one plays,
    go to the Window-->Messages command and copy the information
    listed in the pop up there as it plays the track. Post it back here,
    so that we can figure out what is going on.
  8. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    sounds liek some odd file type that happened to get renamed to .aac
    did you say where you got these files from?!
    If you did, i missed it.
  9. main debug: CPU has capabilities AltiVec FPU
    main debug: looking for memcpy module
    main debug: probing 2 candidates
    main debug: using memcpy module "memcpyaltivec"
    main debug: waiting for thread completion
    main debug: thread 33650176 (playlist) created at priority -47 (src/playlist/playlist.c:80)
    main debug: looking for interface module
    main debug: using interface module "macosx"
    main debug: interface initialized
    main debug: thread 34100224 (manager) created at priority -47 (src/interface/interface.c:118)
    main debug: adding playlist item ´ /Users/daveconte/Desktop/Torrents/FF8/FF8/CD1/10 - ____ - Force Your Way.aac ª ( /Users/daveconte/Desktop/Torrents/FF8/FF8/CD1/10 - ____ - Force Your Way.aac )
    main debug: creating new input thread
    main: playlist item `/Users/daveconte/Desktop/Torrents/FF8/FF8/CD1/10 - ____ - Force Your Way.aac'
    main debug: thread 34321408 (input) created at priority 37 (src/input/input.c:180)
    main debug: access `', demux `', name `/Users/daveconte/Desktop/Torrents/FF8/FF8/CD1/10 - ____ - Force Your Way.aac'
    main debug: looking for access module
    main debug: probing 7 candidates
    dvdplay debug: plugin discarded (not a valid source)
    dvdread warning: dvdread module discarded (not a valid source)
    dvd warning: dvd module discarded (not a valid block device)
    vcd debug: trying .cue file: /Users/daveconte/Desktop/Torrents/FF8/FF8/CD1/10 - ____ - Force Your Way.cue
    vcd warning: could not open /Users/daveconte/Desktop/Torrents/FF8/FF8/CD1/10 - ____ - Force Your Way.aac
    cdda debug: trying .cue file: /Users/daveconte/Desktop/Torrents/FF8/FF8/CD1/10 - ____ - Force Your Way.cue
    cdda warning: could not open /Users/daveconte/Desktop/Torrents/FF8/FF8/CD1/10 - ____ - Force Your Way.aac
    access_file debug: opening file `/Users/daveconte/Desktop/Torrents/FF8/FF8/CD1/10 - ____ - Force Your Way.aac'
    main debug: using access module "access_file"
    main debug: looking for demux module
    main debug: probing 16 candidates
    mp4 warning: MP4 plugin discarded (not a valid file)
    avi warning: avi module discarded (invalid header)
    asf warning: ASF v1.0 plugin discarded (not a valid file)
    ts_dvbpsi warning: TS module discarded (no sync)
    ts warning: TS module discarded (no sync)
    es warning: ES module discarded (no startcode)
    au warning: AU module discarded (not a valid file)
    wav warning: WAV module discarded (not a valid file)
    main debug: looking for id3 module
    id3tag debug: Checking for ID3 tag
    id3tag debug: ID3 tag found, skiping 1162 bytes
    main debug: using id3 module "id3tag"
    main debug: unlocking module "id3tag"
    a52sys warning: A52 module discarded
    mpga warning: mpga module discarded
    mkv warning: matroska module discarded (invalid header 0xfff95080)
    aac debug: adts header: id=1 channels=2 sample_rate=44100
    main debug: selecting ES 0x1
    main debug: looking for decoder module
    main debug: using decoder module "faad"
    main debug: thread 34427904 (decoder) created at priority 37 (src/input/input_dec.c:112)
    main debug: using demux module "aac"
    faad warning: cannot load stream informations
    faad warning: DecoderSpecificInfo missing, trying with first frame
    faad debug: faad intitialized, samplerate: 44100Hz channels: 2
    faad warning: decoded zero sample !
    main debug: no aout present, spawning one
    main debug: looking for audio output module
    main debug: probing 3 candidates
    coreaudio debug: system has [1] device(s)
    coreaudio debug: device [0] has name [Built-in Audio]
    coreaudio debug: device [0] has [1] streams
    coreaudio debug: supported format: [44100][lpcm][30][4][1][4][2][16]
    coreaudio debug: getting device [0]
    coreaudio debug: stream format: [44100][lpcm][30][4][1][4][2][16]
    coreaudio debug: setting format: [44100][lpcm][30][4][1][4][2][16]
    macosx debug: stream has changed, refreshing interface
    coreaudio debug: using format: [44100][lpcm][11][8][1][8][2][32]
    coreaudio debug: device buffer size: [4096]
    main debug: using audio output module "coreaudio"
    main debug: output 'fl32' 44100 Hz Stereo frame=1 samples/8 bytes
    main debug: mixer 'fl32' 44100 Hz Stereo frame=1 samples/8 bytes
    main debug: no need for any filter
    main debug: looking for audio mixer module
    main debug: using audio mixer module "trivial_mixer"
    main debug: input 'fl32' 44100 Hz Stereo frame=1 samples/8 bytes
    main debug: filter(s) 'fl32'->'fl32' 48510 Hz->44100 Hz Stereo->Stereo
    main debug: looking for audio filter module
    main debug: probing 22 candidates
    main debug: using audio filter module "bandlimited_resampler"
    main debug: found a filter for the whole conversion
    main warning: PTS is out of range (24934), dropping buffer
    main warning: PTS is out of range (2842), dropping buffer
    main warning: PTS is out of range (-19468), dropping buffer
    wow... over my head.
    i got these files from an FTP.
    Nov 2003
    they should be .m4a
    blog: deadsierra
  11. Member galactica's Avatar
    Jan 2003
    things I see
    1. illegal characters and spaces in the file path. Take out all that - and ____ and space nonsense!
    2. /Torrents/
    hahahahahahaha .... if you have no luck taking the spaces and characters out id say blame the person who encoded them!
  12. bit torrent, ftp, same difference
    yeah, nothing worked. how lame. oh well, toss that crap out the window. thanks for the help anyway =)
  13. Master of my domain thoughton's Avatar
    England
    So iTunes doesn't allow spaces, hyphens and underscores eh? Who's talking nonsense now?
  14. Member galactica's Avatar
    Jan 2003
    no i was talking in reference for him/her to get info on the file.
    he/she was getting errors when attempting to acces the files type etc with VLC.
    of coarse everyone knows iTunes has no problems with spaces
  15. Master of my domain thoughton's Avatar
    England
    As far as I can see the poster was unable to play his song in iTunes, but was able to play it in VLC.
    Regarding those 'errors', in my experience you get those no matter what type of file you are playing in VLC. That's the way VLC finds the appropriate decoder (by trying them all).
  16. Member terryj's Avatar
    so it is not a AAC ( mp4)
    nor is it au ( generic audio), .wav, .asf, or .avi....
    From what I gather, it was a an HE AAC file, probably encoded by
    someone not properly using WinAmp to encode the file.
    http://www.audiocoding.com/
    Currently, only VLC 0.71a handles these types of files, as the HE spec
    hasn't been assimilated into QT yet.....
    What..? Don't blame me because I happen to "get out" more....
