  1. Hi i just ripped this true lies dvd onto my hardrive. Have all the vob, ifo etc... files , but is there a program that i can select to get rid of the french audio ac3 track? Its just taking up space and i want to get rid of it? Thanks alot
  2. Originally Posted by stryker1080
    There are alot of way to do this but the first to come into mind is DVD Shrink. Second, IfoEdit.
  3. awesome thanks alot
  4. I rip mine with DVD Decrypter. I pressed the "MODE" button and I clicked on the "Stream Processing" tab. It will bring up the audio portion of your
    video and you can uncheck the ones you do not want. I am pretty sure you can rip it from there. I am pretty sure True Lies is a Dual Layer so you
    will need to compress it after you rip it to your folder. You will still have your vobs, ifo etc.. I use DvD2One to compress my video. I have not used DVD Shrink or IFOEdit before. I hope this is helpful
  5. Originally Posted by Renegade6
    I was going to mention DVD DEcrypter on stripping streams but stryker1080 has already ripped his files.
