Page 2 of 2
FirstFirst 1 2
Results 31 to 35 of 35
    Mar 2002
    canada
    Originally Posted by 808smokey
    start-
    settings
    control panel
    click user accounts
    change the way users log on or off
    uncheck the two boxes
    all that does is get rid of the welcome screen, not the login.
  2. Originally Posted by tenders
    start-
    settings
    control panel
    click user accounts
    You have to turn off the Guest account, and delete the other one, ASP.somthing, can't remember what it's called. You can only have one user account on the system. Also you might have to turn off fast user switching in the config.
    CLick start
    run
    type"msconfig" OK
    select services tab
    click service button (to put them alpha order)
    scroll down to "fast user switching"
    uncheck that box
    Restart
    Mar 2002
    canada
    i found an easier way.
    i installed a program called Teak XP and there is a feature on it that bypasses the login
    thanks for your help
  4. Originally Posted by tenders
    Yup, that works too
  5. Banned
    Jan 2004
    Going in Circles
    I would definitely want to add another hard drive as the xp install takes a gig and a half by itself. On a 8 gig drive, you will soon run out of space.
