New to this. Have a VCD film. Plays in Media Player on PC when go into Mpegav folder and execute dat file. Same film won't play on stand alone DVD (Thomson dth4000)always displays no disk on dvd. Think may be the media. If burning film onto new media do I just do a disk copy or burn the dat file within the mpagev folder only in order to play on stand alone dvd??? Or does the dat file have to be converted in order to play on stand alone dvd......(
_________________
<font size=-1>[ This Message was edited by: Megagiga on 2001-07-12 07:45:22 ]</font>
<font size=-1>[ This Message was edited by: megagiga on 2001-07-12 08:47:52 ]</font>
It is the media problem. Try to use CD-RW. I found that Mr. Write CD-RW plays on most picky DVD players.
Where as mrcdr's answer is useful (the same one I've seen about 20 times) you might want to check to see if your DVD player is compatible with CD-R/RW media. I spent $500 on a 3-disc player only to find it was not CD-R/RW compatible. I returned it for a Pioneer which advertised burnable media compatability and the SAME cd had no problems. Hope this helps.
:-p -
Thanks chaps. Think u r right on the not playing cdr/w's. Checked literature and went through this site. Shitty Thomson.
Next question is whats best stand alone dvd: will play cdr, cdrw's, can be multi region, etc. Any suggestions???? Prices????
Stand Alone DVD record Won't Play on PC?
By rkersh409 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 26th Jan 2010, 13:23 -
stand alone dvd players that play .wmv or h.264
By scorpio291 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2009, 11:58 -
*for all who use nero,and dvd wont play in your stand-alone*
By headstate in forum Authoring (DVD)Replies: 182Last Post: 24th Jul 2007, 03:00 -
HELP! DVD's won't play on stand alone players
By jessandjeff123 in forum Newbie / General discussionsReplies: 9Last Post: 7th Jun 2007, 07:59 -
Stand alone player won't play DVD-R
By NHLroyrocks in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 17:53
