I have a movie in a bin format that is an svcd. When I used isobuster to take the video out of the bin file the movie played just fine. I then burned the movie using nero. when i put the movie in my dvd player, which has in the past played vcds and svcd, the movie acted like the vertical hold on the tv was messed up, I did check this and that was not the case. If anyone can tell me how to fix this I would be extremely thankful.
maybe its PAL ?
why not burn the movie IN the bin format - instead of all the extra work ?
I did burn it in the bin format. I extracted it just to make sure the quality was good. How would I tell if it was PAL?
One way you can check is by opening the extracted mpeg with Virtualdub MPEG2, then go to File>File Information. If it's 480x576 and 25fps it's a PAL SVCD.
convert it to ntsc
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 22:56 -
DVD plays on Computer but not built in TV DVD player
By crawlfish in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2008, 08:35 -
dvd plays on stand-aone player & TV, but not on computer
By ibzomie in forum Newbie / General discussionsReplies: 1Last Post: 19th Jan 2008, 16:18 -
Foreign DVD plays on computer but not on DVD player
By johnharlin in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2007, 23:28 -
DVD plays on Sony DVD Player but cannot be read by Computer
By jeneralzod in forum DVD & Blu-ray WritersReplies: 3Last Post: 28th Jun 2007, 22:35
