  1. Member archaeo's Avatar
    Mar 2004
    mountains
    You've ripped and burned hundreds (if not thousands?) of backups...
    I'm curious how well the CPU chip and DVD recorder hold up after such intensive use... Which hardware have you seen wear out first, and how often?
    Burner goes first.
  3. Does anyone know if backing up really taxes the CPU?
  4. Member archaeo's Avatar
    Mar 2004
    mountains
    I know that when I run DVDShrink 'deep anaysis' followed by the encoding process, my CPU (dual 1Ghz p3 xeon) usage is pegged at 100% for close to an hour or more (depending on movie).
    Alright, not trying to toot my own horn here, but I've probably run my processor at 100% in single batches longer than you'll ever run yours at 100% total. Both machines are fine, even the old Celeron holds up under my abuse. I'm talking several years worth of use too, sometimes for days on end, for all kinds of things, especially video processing.
    The rest of the computer (HD, DVD-R, RAM, mobo, power supply, NIC, etc) will die long before the CPU pops out.
    You're fine.
    Just use the burner to burn (not read, not CD, etc), and you'll be good. Also keep it clean, free of dust, and don't let dirty discs into it.
  6. Member archaeo's Avatar
    Mar 2004
    mountains
    Good to hear
    Oct 2002
    Wisconsin
    As for the drive,that can be a real crap shoot! I have had drives fail at under 200 burns(PioneerAO5),and I have a Sony 500a with over 1500 burns.The Sony is still going,although it is now my third string backup.I have seen no indication of the cpu being damaged with my burning.Between home and work,I have over 20,000 dvd backups! Yes,that is correct,Twenty Thousand! These are pretty much all legit copies! School concerts,year books and such.
