  1. Is there a capture card (preferebly with S-Video in) that supports data capture at arbitrary resolutions like 730x500, 400x300, and so on?
    TIA
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    I don't think so. They have to be a standard format when you capture. I'm not sure if you can even do that post-capture. Why would you want to do that? Making it arbitrary will cause video apps to reject it as being non-compliant.
  3. When capturing from VHS, the "video noise" is visible on all sides, but especially at the bottom. Capturing at a higher resolution would allow me to crop the frames without the need for interpolation and resampling. (or at least I would think so )
  4. If you know how to use AviSynth, trying using using the crop and addborders filters. You should be able to crop out the noise and replace it with black space.
    Do you remember when TMPGEnc needed an English patch?
