I have a Sony DVP-S360 DVD/VCD/CD Player and i cant get it to play my vcds
i bought a vcd (or maybe svcd...def not a dvd) from a store and it works perfectly
when i tried to make a vcd through Nero (i have an MPEG-1 file and i automatically added it...nero said it would do the rest) and tried playing it the Sony said No Disc
Can anyone help me out?
THANKS
Results 1 to 14 of 14
o btw my Nero version is 5.5.3.0
and when i pop the vcd in my regular cd drive (computer) a vcd player comes up and i can play it through there
THANKS -
maybe but then how did it play that cd that i bought? (btw...i didn't buy from a store)
It doesn't play CD-R not CD.
All DVD players will play pressed CDs. Many, however, are not designed to play CD-R or CD-RW media and not surprisingly, don't do it well or at all.
Regards.
Michael Tam
w: Morsels of Evidence -
Questi4110...go here and most of your questions will be answered:
https://www.videohelp.com/428.html
I also have a couple of Sony players, and you just need to burn your VCDs on CD-RWs. A strange concept I thought, but at least I can test my VCDs and wipe them without wasting CDs.
Bonepart -
Don't waste your time, per a technical support person @ sony, Most of there units will not play CDR's or CDRW's.
Although a playstation 2 will play a audio CDR, no Video files on CDR or CDRW's.
Get a Daewoo DVG-5000N @ sams club for 99bucks..
plays all, CD,VCD,MP3,XVCD,SVCD,DVD
even raw Mpeg1 or Mpeg2 files..
~C~ -
"Technical support people" usually only give information out that is expedient.
Some models of Sony DVD player ARE designed to play both CD-R and CD-RW and not surprisingly, it does so well.
Many models, however, are not. For these players, though, you can usually still find a brand of either CD-R or CD-RW media that will still work.
Regards.
_________________
Michael Tam
<font size=-1>[ This Message was edited by: vitualis on 2001-11-07 09:03:51 ]</font> -
Hi Questi4110, You could try "prime" CD-R at Office max (if you are in US) It works with my cousin's sony dvd player while others don't.
I have a Sony also and can use Memorex Platinum CD-RW and they work. Bought at Officemax 24.99 for 25 CD-RWs. Lot higher than CDR but they work.
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 16:28 -
SONY VP-7040 playing NTSC 3.58 tapes?
By steve70s in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2010, 11:10 -
DVD units playing VCDs in black and white only.
By electric green in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2008, 13:37 -
problem with playing divx files on sony NS67P ?
By cccf25 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Feb 2008, 08:57 -
Playing vcds on Liteon lvw 5001
By northy44 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 25th Sep 2007, 08:50
