I am attempting to take some music video files I have on several assorted DVDs, with the intention of backing them up together on a single DVD, perhaps with a selection menu, and a 'play all' option.
I have been reading through the articles and guides, but I think there may be a better way than I am trying. I was using DVD Shrink (because it allows a 'preview' of each chapter) - because I needed to know which of the files I actually needed. Then I tried DVD Decrypter to actually rip the seperate parts, but I was having trouble figuring out exactly which parts I wanted (from the naming scheme), even after trying to compare the sizes of the files.
Does anyone know of a good program more tailored to what I am trying to do? Or perhaps know of a more specific guide somewhere? Thanks.
As an Update, I just discovered it is better to use the re-authoring mode of DVD Shrink to drag over the parts I want, then backup to disk. Now I just need to do this with all of the DVDs I want sections for. So that's the first step!
Ia! Ia! http://www.templeofdagon.com/ -
Great guide! Just what I was looking for.
I am attempting it now, I will post back with results!
The tutorial worked great. I ripped from several DVDs and even was able to use TMPGEnc (with the quicktime plugin) to also add in a MOV video I had, converting it to M2V and WAV.
There were just a few issues I need to figure out how to resolve sometime.
1) The menu creation system in TMPGEnc DVD Author leaves a lot to be desired.
2) The sound levels on the different videos were quite a bit different. This is probably due to the differences in the source DVDs, and this may not be really 'fixable'.
3) I cannot hit the 'menu' button while a track is playing, I can only use the foward button to move to the next one. This may be due to the menu editing/authoring system.
Any comments? I see a lot of people mentioning the use of TMPGEnc DVD Author, but are there better ones out there? I found the interface to be kindof clumsy, and not many options as I would of liked.Ia! Ia! http://www.templeofdagon.com/
Ripping my DVDs, taking out scenes and joining them
By theofile in forum DVD RippingReplies: 1Last Post: 9th Mar 2010, 16:14 -
putting vobs to dvds
By chuchi327 in forum Authoring (DVD)Replies: 4Last Post: 23rd Oct 2009, 20:38 -
Taking portions of multiple dvds and put them onto another
By ulremember in forum Authoring (DVD)Replies: 10Last Post: 4th Mar 2009, 19:07 -
Cutting WMV into multiple parts
By craigy27 in forum EditingReplies: 3Last Post: 4th Jul 2008, 05:45 -
Program to manually split multiple parts of same avi?
By majax79 in forum EditingReplies: 5Last Post: 22nd Dec 2007, 11:49
