Is there some way of accurately calculating how long (in minutes) an mpeg can be to fit on 4.37GB DVD-R when resolution and average bitrate is known? This so that I can place just enough video in a Studio9 project without having it to be re-rendered.
Results 1 to 12 of 12
There are no stupid questions, only stupid people.
Unless I have misunderstood your question, it is impossible to estimate permissible length in the absence of a value for average bitrate. It's like saying how far can I go on a tank of fuel in a Mercedes SLK 230 if I don't know the car's fuel consumption rate.Originally Posted by Ruude
I'd like to be able to give you the answer you appear to be reuesting, but I don't see how this is possible.
Arky ;o) -
Ooops! my sincere apologies, Ruude - I read your post too quickly and misread 'known' as 'unknown'. I was wrong, hands downOriginally Posted by jimmalenko
The following may help you:
http://www.dvddemystified.com/files/DVDcalc.xls
Again, please accept my apologies
If this calculator does not help you, then please repost and I'll do my best to help further.
Regards,
Arky ;o) -
90 minutes at 6500 kbps=4.37gb with 224 kbps audio
120 minutes at 4800 kbps=4.37gb with 224 kbps audio
150 minutes at 3800 kbps=4.37gb with 224 kbps audioI think,therefore i am a hamster. -
What about resolution in this estimate?Originally Posted by johns0There are no stupid questions, only stupid people.
Sorry, resolution is not computed in this formula. It has nothing to do with how big space an MPEG will be versus how long it is.
Hello. -
OK, then what about this:Originally Posted by Tommyknocker
a 4 hour video capped at 480x576 with 4.5 bitrate gives about 11gig
--------- -320x576- -------- 7gig
so resolution is definately a factor no?There are no stupid questions, only stupid people. -
Either the video is shorter or the bitrate is lower. Resolution is not a factor. Bitrate is exactly as the name suggests. The amount of bits of data over time, resolution does not effect this.Originally Posted by Ruude
This is nice, but I want to go the other way round.Originally Posted by BJ_MThere are no stupid questions, only stupid people.
you can use it to figure out either way -- its not hard at all"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Date/Time Stamp for HDV Footage
By lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 26Last Post: 18th Mar 2019, 03:25 -
Very 1st time exposed to straight AVCHD footage: HELP !!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 5Last Post: 31st Jul 2011, 18:37 -
Trying to make a time-lapse video (speeding up original footage): How?
By maskingtape in forum EditingReplies: 30Last Post: 16th Jul 2010, 00:39 -
footage from 5d Mark II mixed with XLII footage
By segan in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2010, 15:24 -
Security Time Lapse Footage to DivX/Xvid
By NightFire in forum Video ConversionReplies: 4Last Post: 2nd Feb 2010, 23:51
