I want to make a downloadable vcd image file ready for burning on mac or pc, with (almost) every cd burning application available.
Making a vcd is no problem, on mac with toast or Vcd Builder, on a PC with VCDeasy.
But I want one downloadable file that can be burned to cd easy, on a Mac AND on a PC. Just download the file and burn.
So I thought that making an .iso file would do the trick.
I tried to convert a .nrg (nero) to .iso.
Or a cue/bin file to .iso. And a lot of other things. All did not work.
The cue/bin file is the best option till now, it works, but it didn't import well in Nero 5.4.4.0. (it did in nero 6) and it's also not possible to burn with EasyCd creator as I understood.
Who knows THE trick?
Please help! Spend days on this already!
Thanks for reading, a lot of thanks for answering!
Martin, http://www.park.nl
I think you are better off sticking with a bin and cue image. If someone really wants your VCD they'll get the appropriate software to burn the image if they don't have it already.
How to create a nice-looking image montage?
By jeanpave in forum EditingReplies: 2Last Post: 14th Jan 2011, 22:22 -
Is the feature Internet stream ready same as Wi-Fi ready on the Blu-ray DVD
By coody in forum DVD & Blu-ray PlayersReplies: 9Last Post: 22nd Nov 2010, 20:09 -
Need help converting DVD to downloadable file for retail
By Hoopii in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2010, 13:51 -
How to create an ISO image file from a disc under UNIX.
By valeyard1492 in forum LinuxReplies: 11Last Post: 11th Sep 2009, 19:11 -
Create one image from overlaying several frames?
By sincostan in forum Newbie / General discussionsReplies: 15Last Post: 15th Oct 2007, 11:07
