Results 1 to 14 of 14
  1. I have a lot of old videos that are beggining to degrade, and have started to capture some onto DVD with a Dazzle capture card. However, it takes almost half a day to capture/encode the file for DVD. I'm wondering if anyone can tell me a good good capture card that would capture the video is realtime mpeg2 so I can burn it to a DVD right away. I have tried programs like Ulead movie factory to capture realtime, but doesn't support my card, gives me some weird error about copyrights. I am not so concerned with the quality, but am about time. Thanks in advance for any help.
    Apr 2002
    The State of Frustration
    Ulead products, like Video Studio 7 can capture in DVD MPEG-2 format. It has a 30 day trial period.
    Hello.
    And your cards is a .... ?
  4. Mod Neophyte redwudz's Avatar
    USA
    Cost a few $, but you could use a ADVC-100 or similar and Mainconcept encoder. Convert VHS directly to MPG2. If no editing is needed, author with TMPGEnc DVD Author and burn to DVD. Can't get much easier.
  5. Find an ATI All In Wonder card. I can capture full D1 MPEG2 with no dropped frames.
  6. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    Can you tell us a little about your system (cpu, memory amount, hard drives). You may need a hardware capture and encoding solution like a Haupagge PVR-250.
  7. Thanks for all the post guys. My current capture card is a "Dazzle Hollywood DV-Bridge". My system is a P4 2.8C (hyperthread) and I overclocked it to a 3.2ghz. It also has 512mb of Dual Channel PC 3200 DDR ram, and a regular 7,000RPM ATA/100 200gig Hard drive. I have tried Ulead Video Studio 7 before, and gave me an error about Copyrights after around 2 minutes of capturing realtime mpeg2.
  8. MPEG-2 usage needs to be unlocked somehow..
    This only applies to the US. Nowhere else...
    There are no stupid questions, only stupid people.
  9. Since you have a lot of tapes, don't want to spend a lot of time on it and you're not too concerned about quality, you should consider a DVD recorder (if it's not outside your budget).
  10. Sounds like for what you want to do (direct transfer from VHS to DVD, no menu's etc) a DVD recorder may be the way to go.
  11. I thought about one of those, but a bit out of my budget. I am wondering if there is some kind of cheap capture card or software around 100-200$. Thanks for all the help though.
  12. Member teegee420's Avatar
    Dec 2003
    Southern California
    My vote is for an ATI All-In-Wonder. Head over to pricewatch.com and click on "cards- video"(not capture). The 7500(which I own) through the 9600 are well within your price range.
  13. Member stackner's Avatar
    Feb 2004
    Digital World, Australia
    if you must capture direct to mpeg-2 then go download POWERVCR-2 it can capture direct to mpeg-1, mpeg-2, vcd, svcd, dvd, ect. i used it a lot. but i have learnt as many people have that it is best to capture to AVI then convert to MPEG. even on tapes i dont want to edit i do this as my end quality is better than straigh mpeg capture unless i want a 30 mins clip to fill a whole dvdr.
    Jan 2004
    Canada
    ATI AIW for direct software encoding. Plextor ConvertX 2 for direct hardware encoding.
