Awaiting for your advise everybody experts there.
I want to transfer my old VHS videos to VCD or DVD for watching them on TV. Which is the best capturing resolution for PAL system? I have confused among 702x576, 704x576, 720x576 and 768x576. Which is the right one? I am not interesting in watching the videos on my PC but just only on my TV (DAR 4:3, PAL). Should I deinterlace it or not?
Results 1 to 9 of 9
I'm not real familiar with the PAL world, but I would use 1/2 D1 resolution of 352 X 576, should be plenty sufficient for VHS and will allow a lower bitrate. Usually keep interlacing if you are going to watch on a TV. Check the DVDR info to the left, then the 'Guides' for more info.
Help's to know what capture card you use. you can try 720*480 or 352*480. for VCD I like to capture you DVD then encode to VCD with TMPG.
352x576
I use a AvetTV Studio 303 card with Conexant cx23881 chipset. Which is the best software for video capturing? For now I'm trying the iuVCR Trial version and it seems good. Any alternative good software? What about virtualVCR for for my own card?
I always used 352x576 (480) for VHS captures...
the software I play is VirtualDub only, with a MJPEG codec in compression, like PICVIDEO... works great... if you want to edit, you should try to capture losslessly with specific codecs.
Fred© -
Originally Posted by Fred©
Originally Posted by AlexCR
The original VHS is even "more narrow" than the 352.
They both playback at the same size, 4:3Want my help? Ask here! (not via PM!)
AlexCR: The 480 in brackets is just the NTSC alternative resolution. Doesn't apply to PAL.
Capturing VHS to PC with a high definition resolution...?
By dark_myuutwo in forum Capturing and VCRReplies: 108Last Post: 10th Jun 2016, 11:18 -
Capturing Netflix Instant Viewing
By PharmBoy in forum Capturing and VCRReplies: 24Last Post: 28th Feb 2011, 03:11 -
What Windows resolution for viewing 720/1080 MKV's?
By leopardx in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2009, 19:43 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
Qaulity Capture Card for VHS-DVD & Computer TV Viewing/Capturing
By RubicksCube13 in forum Capturing and VCRReplies: 1Last Post: 11th Nov 2007, 08:00
