short form intro is that Samsung digital cam corders do not use the same technology as JVC, Sony, Panasonic, Canon. These 4 are compatible with each other....I had a samsung that destroyed itself... I was checking around to find which camcorder would play my edited tapes which amounted to 1000's of hours of work. Non of them would.. The picture was there but the sound refused to be played on the 16 bit that I'm sure was saved as. It only played on 12 bit which gave this alien sound that was not hearable. I need a program that will enable me to mess with the bit ratio and frequencies so I can record it again with compatible for known popular makes....My only copies are these mini DV which I figured was a standard for all digital cam corders... Any help here would be appreaciated...
Bill
Results 1 to 1 of 1
Audio/Mic problem during filming, need a solution..
By sdsumike619 in forum AudioReplies: 16Last Post: 31st Jan 2012, 18:17 -
DRM hardware solution needed for stream to HDD/DVD Recorder
By SkyerFlyer in forum DVD & Blu-ray RecordersReplies: 5Last Post: 20th Feb 2011, 05:32 -
Samsung vp-w70 HI8 problem(white snow) - solution needed!
By 850nm in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 29th Jun 2010, 21:07 -
Is FLV splitter the solution or what's needed?
By tigerb in forum Newbie / General discussionsReplies: 4Last Post: 28th Aug 2009, 02:45 -
AVS/VDM-based solution needed for color correction
By hollowman in forum Newbie / General discussionsReplies: 0Last Post: 25th Aug 2008, 04:51
