first is there any way to specify a start time or frame for encoding?
my second problem is once ive encoded something, typically a larger file like 700+ mb avi, when i try to open it explorer crashes.. the file still plays but exploreres shell closes and opens up again. anyone else encounter this problem?
Phone Anglian .. and re-install windows.
there is no way to set start and end frames, unless you edit the vobs.Corned beef is now made to a higher standard than at any time in history.
found out why my explorer was crashing.. was a bug with the codec i was using and whenever it tried to display a thumbnail it would crash...
anyway that sucks about the start points hopefully it will be implemented on future versions.
AutoGK problems
By Arlo in forum DVD RippingReplies: 11Last Post: 11th Jan 2009, 12:34 -
AutoGK - experiences and problems of ripping a larger movie collection
By vchrizz in forum DVD RippingReplies: 2Last Post: 22nd Sep 2008, 17:43 -
Problems using AutoGK
By shapper in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jun 2008, 21:03 -
Help with AutoGK please
By smackyourfupa in forum DVD RippingReplies: 7Last Post: 29th Nov 2007, 02:21 -
Subtitles problems w/ DVD Decrypter and AutoGK
By coyotewrw in forum DVD RippingReplies: 2Last Post: 4th Aug 2007, 14:15
