I have backed up my Matrix Revolutions DVD with 87% compression for the movie only. The disc plays fine on both my PC's DVD drives. It will not however play on my Sony DVPNS930V standalone player. I burned onto Memorex 4x DVD-R media with a Sony DW-U18A writer. This usually works fine. A friend of mine says he has had the same problems with DVD shrink on his NEC burner with different media, so uses DVD X copy instead with no problems. I have used DVD shrink before with a different burner and had this problem come up once before. On other occasions it has worked fine. Am I doing something wrong? The AUDIO_TS and VIDEO_TS folders are there as well as the BUP and IFO files.
What does it do? Skip, stutter, give an error message? Need more info. What speed are you burning at? Have you tried a lower write speed?
I personally get better results transcoding to a ISO image and burning with DVDDecrypter then I do transcoding to VOB files and burning with Nero. As far as DVD X Copy goes. I've played around with it a little bit. Never really backed anything up with it though. So I can't really comment on that. But I can tell you most seem to not like it to much around here. -
Very strange. Just tried it again to get the error message and it played fine!
I have an older. finicky standalone, and when I burn to an ISO I've never had a problem.
Originally Posted by banana_man
It says in my instructions to try the disk more then once if it does'nt work right away. -
is that movie even out yet? I thought it was released april 6th
Hunting, sure i'll go hunting. When is cow season?
Converting 1080 blu ray backup to play on PS3
By spideygower in forum Newbie / General discussionsReplies: 2Last Post: 20th Jan 2011, 14:37 -
Blu-ray backup won't play in PS3
By DGenerateKane in forum Blu-ray RippingReplies: 40Last Post: 27th May 2010, 00:57 -
How can I play a backup DVD on my PS3?
By ZQ8_Blazer in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2008, 05:08 -
Samsung ht q-100 can't play backup DVD's???
By infoman99 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 16th Oct 2007, 12:09 -
Is there any standalone device that can play backup DVDs from a HD?
By pwangdel in forum Media Center PC / MediaCentersReplies: 8Last Post: 25th Jun 2007, 19:31
